Barry's RV14A
Date:  9-18-2022
Number of Hours:  8.30
Manual Reference:  N/A
Brief Description:  It's a Wrap. Well, Not Really...
From 9/16 through 9/18 - As assembled & shipped by SteinAir, I found that the circuit breaker board would not fit through the wiring channel that is attached to the panel & the tunnel. I had the option of re-routing the harness but; I did not like that look. So, I removed thirty screws & wires from the assembly, stuffed it through the channel & re-connected everything; triple checking my work with the electrical schematic.
Once the circuit board panel was properly positioned I continued routing, bundling, lacing & stuffing wiring to their respective positions within the airframe. I am definitely making headway as I strive to be as neat about the process as I can. Lacing bundled wires may be over-kill in some builders minds but, for me; it's a relaxing task. The bonus to all of this is that lacing simplifies wire routing, aids in troubleshooting & overall; it's a professional touch.
