Brief Description: Return To Panel Installation...
From 8/29 thru 9/2, continued with the installation of the panel's remote boxes & routing the wiring. All remote boxes now permanently installed, connections are made & I am now ready to clean-up the area by bundling the harnesses as neatly as possible.
Next is to feed wires through the firewall for CHT, EGT, E-Mag power, etc. and to mount the grounding terminal & main bus blocks to the interior side of the firewall.
