Barry's RV14A
Date:  8-3-2022
Number of Hours:  3.50
Manual Reference:  N/A
Brief Description:  Plan C...
As I have done with the left side, I am back to the vertical mounting option for the GTX45 & GAD29 on the right. The GDL51 will now be mounting to the forward side of the sub panel. Unfortunately, the hinging option for the GTX45 will not be added as there is not sufficient structure available to securely attach it. I did however modify the mount to ease removal of the transponder for servicing.
The back-ordered GSU-25C AHRS module arrived from SteinAir today. I attached it to the PFD for now, but it may end up on the MFD if space is tight on the left.
