Brief Description: Remove Canopy - See Notes to Right
1. Removed canopy from frame to deepen the countersunk holes at the side rails. It was determined that the side rails would not marry up to the canopy due to the #6 holes not being deep enough.
2. With the canopy off, we elected to match drill the two canopy shims to the side rails; should they be required at final assembly. However, the canopy's thickness exceeds the minimum thickness & does not warrant the use of the shims. Deburring & match drilling of the shims is solely a proactive step.
