The once dimpled rivet & nutplate holes had to be flatten to insert the wing rib. Now that it is in place & the ProSeal is curing, I went ahead & re-dimpled the once flatten holes. Finished up the day by riveting everything back together.
Will apply additional ProSeal to the inside of the rib & then finish off this project by sealing the exterior portion.
