Additional prepping is being completed for the big move from my garage to hangar G-47 at KAKR. The transport is scheduled for 2/2/2023 @ 13:00. I still need to temporarily install the rear window & buckle everything down for the ride east.
For me, I noticed I reached a point in the assembly process where I became a bit less productive. This is probably due to working on bits & pieces of the build with little guidance. But, once the bird is settled into its hangar, the tail section will be attached, the left wing will be repaired (fuel tank). Then both wings will have their remaining two skins installed & finally, the wings will be permanently attached to the fuselage.
Things will eventually come together.
I always welcomed visitors. Text me anytime @ (330) 414.0082. Thanks.
