Spent several hours installing the strip lighting for the glare shield. The 36" length of strip was finally cut down to 28". Any longer & the lights bending around the brow interfered with one's vision. Clothes pins are used to hold the adhesive strip in place for a 24-hour adhering period. Based on the initial contact, I don't believe this lightweight strip is going to come loose easily.
Started wrapping the wiring bundle into 1/4' flex tubing. Once the adhesive bonding time is up I will hard-wire the glare shield strip to the wire bundle & finish the flex tubing task. Only two more wires to connect; the baggage compartment overhead light & the footwell lights. Those two may wait until after first flight – or not…
