Barry's RV14A
Date:  10-1-2023
Number of Hours:  3.00
Manual Reference:  Sect. 20
Brief Description:  Access Cover & Doublers....
Attached together the two VA-195D access cover plates with a single VA-195C doubler, inserted it within the access panel cutout & used that assembly as a template to determine the rivet hole locations on the skin panels. Just a bit of additional trimming to the access holes was required that then allowed the cover plates to sit in each housing. Once there, I aligned them squarely & marked their rivet hole locations on the skin panel.
Disassembled components, trimmed, filed & polished. Cleaned then primed. Installed nutplates. Dimpled bottom skin panel.
** It will be a few weeks before I return to the project as Jameson, our Irish Setter, is undergoing a total left hip replacement 10/2/23. The surgery will take place at the Ohio State University Veterinary Medical Center. He will require 100% of my care, post-op, for at least two weeks, if not more.
