Barry's RV14A
RV14A-QB
N/A
Rotisserie Height Extension...
Found that I needed just a bit more height to the rotisserie in order for it to fully rotate 360 degrees. Left the original height hole intact should; I ever wish to revert to the original option.
Also added casters & offset supports.
RV14A-QB Home
2416
309
Brake System
Canopy & Window
86
148
Control Sticks
Cowling
77
118
Elevators
Exhaust System
Fairings
57
105
Finishing Kit
Flap System
Flight Controls
269
Gear Assembly
Horizontal Stab.
Ignition System
Inventory
Lighting
25
Note(s)
Oil Cooler Assy.
Phase Inspection
Prime/Paint
Propeller
Protection Devices
Research
Service Bulletin
Trim & Trim Tabs
Vent
Vertical Stabilizer
Wheel Pants
271
