Routed the GAP-26 wiring through the wing. Added terminal connections & secured the ground, discrete & power leads. Then coupled those wires to the remote box leads, heat shrunk & bundled for a clean & secured fit.
Will trim out 1/4" static & AOA lines next so that they can be easily connected during the wing's closed-up riveting session.
