Barry's RV14A
RV14A-QB
Sect. 18
Fuel Tank Leak Checks C/W...
Completed the right fuel tank leak check - passed. Place terminal rings of sender wires & attached.
Onto mounting the aileron trim control unit, double checking the assembly checks & then attaching the two bottom skins for each wing.
RV14A-QB Home
2416
309
Brake System
Canopy & Window
86
148
Control Sticks
Cowling
77
118
Elevators
Exhaust System
Fairings
57
105
Finishing Kit
Flap System
Flight Controls
269
Gear Assembly
Horizontal Stab.
Ignition System
Inventory
Lighting
25
Note(s)
Oil Cooler Assy.
Phase Inspection
Prime/Paint
Propeller
Protection Devices
Research
Service Bulletin
Trim & Trim Tabs
Vent
Vertical Stabilizer
Wheel Pants
271
