Prepared the engine control mount for installation. This required enlarging the four hole in the face to accept the respective controlling cables. Debur the unit & bolted it to the instrument panel.
I installed the Throttle, Propeller Governor, Mixture Control & Alternate Static Air control cables. Fed each cable through the firewall & routed them to their designated areas. All final connections will be completed in the next day or two. I did notice that I will need to reindex the throttle body's fuel allocation arm as it is currently about 150 degrees out of where it needs to be. The rest of the cable alignments appear to be okay.
