Barry's RV14A
Date:  9-15-2022
Number of Hours:  6.80
Manual Reference:  N/A
Brief Description:  67% There...
From 9/8 through 9/14 - Continued organizing the avionics panel wiring. The Main Bus plate has been installed as has the 48 Tab Grounding Plate. I elected to go ahead & attach the 5/16" ground bolt to the plate even though it is unlikely it will be needed.
Started to install the wiring channel & found that the collection of wiring harnesses going to the GTN750Xi could have been a tad bit longer in length. To ward-off wire chaffing, I notched-out the upper right corner of the plate & attached an edge strip.
Starting today I will be cutting to length & attaching the terminals to the ground wires (43 of them) & then connect those to the grounding plate.
