Brief Description: Flap Position Sensor Installion - See Notes to Rig
*** What they didn't tell you back in Section 34 that you wish they would have...
For those that are building & have not yet reached section 34; Heads-Up! Do yourself a big favor & review Section 54 regarding the installation of the Flap Position Sensor prior to starting section 34. Part # WD-1013A needs to have a single #30 hole drill in it to accept the pushrod for the sensor. DO THIS when you are completing Section 34. Otherwise, you'll have to remove the entire assembly later down the road (as I had to) just to drill one hole in the bell crank. It's time consuming & it's one of those things no one mentions - but I now have!
