Barry's RV14A
RV14A-QB
Sect. 38
Final Sanding of Gap Filler - See Notes to Right
1. Remove excess Filler for Fiberglass Adhesion
2. Final Sanding of Gap Filler Area & Buffing of Froward Canopy Area
3. Removed Most Taped Off Areas & Re-Applied Fresh Tape
3. Began cutting fiberglass cloth as directed in plans, but found that I had initally ordered the wrong weight, 10 oz. Reordered 8 oz cloth.
RV14A-QB Home
2416
309
Brake System
Canopy & Window
86
148
Control Sticks
Cowling
77
118
Elevators
Exhaust System
Fairings
57
105
Finishing Kit
Flap System
Flight Controls
269
Gear Assembly
Horizontal Stab.
Ignition System
Inventory
Lighting
25
Note(s)
Oil Cooler Assy.
Phase Inspection
Prime/Paint
Propeller
Protection Devices
Research
Service Bulletin
Trim & Trim Tabs
Vent
Vertical Stabilizer
Wheel Pants
271
