Barry's RV14A
Date:  11-16-2020
Number of Hours:  2.75
Manual Reference:  SB-00027
Brief Description:  Performed SB-00027 As Directed
Tach Time: N/A
Aircraft Kit: #140576
Van’s Aircraft Service Bulletin SB-00027, Dated 11/5/2020
C/W Date: 11/16/2020
* Removed Nose Gear Leg U-01406
* Removed Nose Gear Link Assembly U-01416
* Cut away material from the aft end of the Nose Gear Leg opening where the Nose Gear Link attaches, per SB-00027
* File, sand smooth, polish & prime exposed metal
* Re-attach Nose Gear Link Assembly U-01416 with Washer-00023
* Fully torque Nose Gear Link assembly nut MS21045-6
* Applied torque seal to nut MS21045-6
* Reattach Nose Gear Leg U-01406
* Fully torque all associated Nose Gear Leg hardware
* Performed operations check on all nose gear assemblies. No defects noted
Barry M. Wawrin, Builder/Owner
