Barry's RV14A
RV14A-QB
Sect. 19
Route Wiring Harnesses for Left Wing - See Notes
... WH-00011 Wing Tip Lighting Harness
... WH-00012 AHARSS Harness
1. Had to remove all of the lacing I install on this wiring harness as Van's used to different size snap rings along its route.
2 Removed three small snap rings (SB375-4) and installed 1/2" snap rings (SB500-6)
3. Same may be said for the right wing tomorrow.
RV14A-QB Home
2416
309
Brake System
Canopy & Window
86
148
Control Sticks
Cowling
77
118
Elevators
Exhaust System
Fairings
57
105
Finishing Kit
Flap System
Flight Controls
269
Gear Assembly
Horizontal Stab.
Ignition System
Inventory
Lighting
25
Note(s)
Oil Cooler Assy.
Phase Inspection
Prime/Paint
Propeller
Protection Devices
Research
Service Bulletin
Trim & Trim Tabs
Vent
Vertical Stabilizer
Wheel Pants
271
