Continued with fitting the cowl by sanding and adjusting. Cut and drilled the side lower cowl to fuselage hinges. Cut and drilled the lower aft cowl to fuselage hinges. I also manufactured hinge pin retainer clips. These clips will hold the pins in place on the top aft and lower aft hinges, and will be installed later.
