I wanted to accomplish a few items today. I moved the aircraft around the shop and rearranged the work benches so that I could place the nose outside. I wanted to test the starter circuit and the shop ceiling is too low to allow the prop to spin fully. I also wanted to rotate the cylinders to spread some of the preservative oil around the cylinders. I also wanted to assure myself that the airplane will indeed fit through the door when it is time to move to the airport!
Everything went as planned with the starter working perfectly, the cylinders getting oiled and the airplane does indeed fit through the doors!
