Brief Description: Prop Installed and safety wired
With the baffles and majority of the engine wiring completed I reinstalled the prop and torqued the bolts. I used an adapter on my torque wrench which is designed specifically for the Lycoming to allow access to the prop bolts. You then use a formula to determine the torque to use with the adapter. I then safetied the bolts and the prop is now installed for the final time.
