The prop governor line must pass through the right forward baffel floor on it's way to the rear of the engine. I drilled the hole and fitted a rubber grommet and passed the oil line through. The hole must go through part of the baffel support flange and is too thich for a normal grommet, so I had to cut and modify the grommet, and will fill with RTV to seal the hole.
