I installed the control cable for the purge valve. I had previously installed a mounting bracket below the instrument panel and ran the cable through a firewall penetration. I then routed the cable up the engine mount and through the rear baffles, then across the engine to the purge valve. I secured the cable in several spots with cushioned clamps.
