Brief Description: Modify throttle and mixture control cable supports
I modified the mixture bracket by riveting an aluminum section to the existing bracket. The cable support hole is now moved aft about 2" and will fit the location of the cable nuts. The throttle cable support only needed to be reversed on the mounting holes to provide the same effect for that cable. The throttle cable also passes through the forward cockpit cover and required drilling and installation of a plastic bushing.
