Brief Description: Installed throttle and mixture cable brackets. Se
I installed the modified mixture and throttle cable support brackets. The mixture bracket is secured by the sump attachment bolts and nuts. The throttle support bolts are safetied. I also torqued the prop governor attachment nuts and reinstalled and safety wired the oil filter. the oil filter was removed to provide better access to the governor.
