Brief Description: Manifold pressure transducer and line.
I mounted the manifold pressure transducer onto the rear of the upper firewall with nutplates. I drilled and mounted the manifold pressure firewall fitting below the transducer. I then attached the hose between the number 3 cylinder and the firewall fitting. I'm waiting for some plastic tubing and fittings to finish the transducer connections inside the cockpit.
Manifold pressure transducer (above) and the manifold pressure hose fitting (below)
Manifold pressure line from #3 cylinder to the firewall fitting.
