I installed the alternator mounting bracket onto the engine. I had to move the mounting holes on the bracket slightly to position the alternator pulley directly in line with the ring pulley. I manufactured and drilled the forward support bracket. This bracket and the adjustment support arm both needed a slight joggle to correctly align to the alternator. I installed the belt and adjusted and tightened all nuts, and safetied in place.
