I attached the breather tube to the upper rear of the engine. I drilled and riveted a nutplate to attach the aluminum tube that runs down the firewall. The view from below shows the aluminum tube which will later be secured at the lower firewall and positioned above the exhaust, where any drips will be burnt off. I them installed and safety wired into the place the oil dipstick.
