Brief Description: Flap Position Indicator Calibration
When the flaps were installed I then calibrated the position indicator. This is fairly easy to do. The ACS engine monitor has a calibration page where you raise the flaps and hit the Calibrate key, then place the flaps to full down and hit the key again. The flap position indicator then uses this to show all flap position from full up to full down.
