I installed the pitot tube and pitot heat attachments in the left wing.
I also did some minor fiberglass work on the lower rudder tip. When I installed the rudder there was some minor interference between the fiberglass tip and the vertical stabilizer mounting bolts. Not enough to feel in the rudder pedals but it would probably result in scratched paint on the rudder tip. I trimmed the forware edge of the rudder tip and decided to enclose the forward end of the rudder so applied some fiberglass.
