I installed the 8 wing attach bolts into the wing spar connector. I had put a light coat of oil on the bolts and they went in without much trouble. The only difficulty was with the lower bolts as I had to use the rubber mallet and there is very little room. I'll put the nuts on and torque these next week.
With the bolts in place I removed the supports and the wings are on for good.
