Brief Description: Aft Wing Spar and Fuel Tank Secured
I added the bolt, nut and cotter pin to secure the rear spar to the fuselage on each side. I then added the nut, washer and lock bolt to the forward wing/fuel tank bracket and safetied it in place. This nut is only tightened enough to stop the washer from spinning as this fitting is designed to separate in the event of a crash. This way the wing will separate from the fuselage removing the fuel tank from the area.
