Needed to trim seat supports to allow full control movement. Set the ailerons at the neutral, faired position and the control stick to 90 degrees, and adjusted the aileron control rods. Insured that the ailerons and flap trailing edges were faired. Adjusted and installed the control stick linkages. Drilled and dimpled the wing to fuselage fairing. Trimmed the fairing to allow proper clearance with the fuselage.
