Brief Description: Fuel lines from wing to fuselage
Cut and bent the fuel vent line between the wings and fuselage. Drilled the access holes and installed fittings for the vent line. Cut and bent the fuel supply lines from the wings to the fuselage to the cockpit fuel selector valve. Drilled the fuselage access hole and installed the rubber grommet for this line.
