Brief Description: Installed flap rod and control links
Installed the flap control rod, and drilled the fuselage hole for the rod. Adjusted the rod ends to allow proper flap up and down positioning. Trimmed the inboard flap skin to avoid contact with the fuselage. Installed the control column linkages into the cockpit.
