Brief Description: Etching of CB panel, labels and fuel caps
I worked on gathering miscelleanous things that will need to be etched. The fuel tanks need some kind of label stating the type and quantity of fuel so I decided to have the fuel caps engraved with this information along with the N number.
My circuit breaker panel also needed to be re-done as I have added 4 CB's since this was done. I'll have the new CB's labeled and the lines around the various areas re-done.
I also need labels for each switch and control on the instrument panel. Most DAR inspectors want enough labels to allow any pilot to understand the controls and function of every control in your cockpit. I created a template for the throttle quadrant, and all panel controls and sent them and the fuel caps to Aircraft Engraving.
