Brief Description: GPS antenna, ELT and Lift Table
I had ordered an adapter for the GPS antenna connection - to attach the coax antenna cable with a BNC fitting to the TNC fitting on the antenna. The adapter worked perfectly.
I also reinstalled the ELT unit that I had removed to gain access to the aft fuselage to install the antennas. With the GPS antenna now done I could finish up the ELT. I also cleaned up the electrical wire runs in the floor area. I shouldn't have to access the area aft of the baggage wall again before the first flight.
Work on the gear will require raising the gear off the ground several times to fit the wheel pants and gear fairings and in the future to change tires, check brakes etc. I decided to get a lift table which fits nicely under the wing spar or under the fuselage and has a 1000 pound capacity.
