I continued with the gear fairings by deburring the holes in the hinge and countersinking the fiberglass. I then riveted the hinge in place then did a trial fit on the gear. I had to do some trimming of the ends to allow room for the brake lines at the lower end and fuselage at the upper end.
The fairings will be held in place with clamps at the upper and lower ends. Intersection fairings will be added at the top and bottom.
