Bobs RV7 Site
Date:  10-13-2005
Number of Hours:  6.70
Brief Description:  Rewiring the trim and pilot stick
I began by manufacturing mounts for the terminals to be located between ribs below the pilots seat. I then separated the existing wiring, and had to add extensions to most of the wires to allow runs to the new blocks. The working room was very limited and uncomfortable and the going was tedious. Once the old connectors were removed I routed the wiring following a schematic I had drawn. Some new access holes for the wiring runs were made and plastic inserts installed.
