Checked that the HS was still perfectly level, then drilled the forward spar to the spacers and fuselage. I modified the measurements shown in the plans to allow for better edge distance for the bolt. Once I triple checked that the HS was level for the tenth time, I final drilled the holes to receive correct AN bolt.
Everything leveled up relative to the fuselage
Forward spar bolt holes drilled and bolts installed
