Trimmed the bottom of the forward Vertical Stabilizer spar, touched up the trimmed area with primer, then attached to the fuselage with attach plate and spacer using clamps. Cut a piect of angle aluminum stock to serve as straightedge for measuring the position of the VS relative to the fuselage.
