Brief Description: Deburred and Dimpled Right HS Skin
Deburred and finished the edges if the right HS Skin IAW the Van's Construction Manual. Dimpled the Right HS Skin using the DRDT-2 Dimpler with good results. Some maring along the rivet lines from dragging the skins along the dimpling die, but the scratches are very shallow and should be easy to clean up with little more than rubbing compound.
