Brief Description: Riveted Forward HS Spar and Preped HS Skins
Riveted the forward HS spar IAW Van's Construction Manual. Squeezer not able to be used on all rivets so had to bang a few with the gun, results were good but some room for improvement remains! Prepaired the HS Skins for work by removing inner blue covering and removed the covering around the rivet holes on the outside with a grinded soldering iron, results were great!
