Brief Description: Deburred, Dimpled and Primed HS Skins
Deburred and dimpled HS Skins IAW Van's Construction Manual. Had first screw up, pressed dimple die through and made second hole, very close to original hold, looks like a punched 8. Fix appears to be simply placing a rivet in the hole and proceeding onwards. The "oops" is on center enough such that the rivet head almost covers the entire hole, and the painting process will mask the rest. Primed the inside of the skins with Duplicolor Primer.
