Brief Description: Match Drilled and Deburred Rear Spar Assemblly
Completed all items under Rear Spar Assembly on page 6-1 of Van's Aircraft RV-8/8A Construction Manual. Broke edges of HS-609PP Spar Reinforcing bars and rounded ends IAW Construction manual. Match Drilled HS-609PP to HS-603PP. Match drilled, deburred and riveted VA-146 IAW Construction Manual. Match drilled all HS-412PP and HS-413PP Elevator attach hinges IAW Construction Manual.
Getting reinforcing bars to match up with spar channel filet.
Finished match drilling, working on drilling VA-146
