Added plate nuts to left wing tip, countersunk wing tip and dimpled wing covers. Installed wing tip to test fit. Fit OK. Removed wing tip to work on AOA install. Determined how to run AOA tubing through wing. Then ran both AOA tubes through a plastic tube and ran the plastic tube through existing gaps in the wing ribs. Viola! Tubing protects AOA tubes and is secure against the wing skin. Then installed both the upper AOA port and bottom AOA port sealing them with tank sealant. Connected AOA tubing to both ports then drilled out hole for water removal from upper AOA port.Removed instrument panel from aircraft and countersunk panel for F703 trim angle. Primed trim angle and riveted trim angles to instrument panel. Now ready to start with tip-up canopy installation.
