Routed the right fuel drain forward vent line and routed the center fuel line through the isolation blocks. Need tubing bender for the large fuel lines. Decided to make the aft baggage floors removable for access to the step assemblies if needed. Drilled out floor supports for plate nuts and began assembly of plate nuts needed. Also began work on the forward cabin covers by preping all parts.
