Rough routed the center main fuel line through the isolation blocks and made major bends with a tubing bender. Inserted left fuel line into position with left gear mount loose. Setup large bends for fuel line to exit to wing and adjusted lines for fit with lefrt gear mount in place. Bolted left gear mount into permanent position and made further adjustments on left brake and fuel lines to get near finished fit. Next up: right side lines!
