Removed rudder for additional red painting. Final install of elevators. Tested range of motion of elevators. Final assembly of manual trim to left elevator. Final trim of fuel tank and vent lines in preparation for final mounting of wings. Tested battery charging thru panel mounted DC power plug - works OK! Mounted both wings and installed close tolerance bolts and nuts. Tight fit and difficult to start nuts behind wheel mount bracket - but with help we persevered! Now starting to look like an airplane! Connected fuel tank and vent lines and connected wiring at wing roots - still need to test wiring again and seal inside wing roots.
