Made the big move today. Loaded fuselage onto truck, secured fuselage, and then moved it to the airport. Unloaded fuselage at airport and backed it into the hangar. Then mounted horizontal and vertical stabilizers. Temp mounted rudder to determine where red paint line required. Also marked off white/red transition line onto bottom rudder fiberglass. Need to now paint these parts to complete the rudder painting. Prior to the move to the airport, we also completed drilling the nose wheel intersection fairing mounting hardware. Now just need to complete prep work on the nosewheel pants and fairings so we can get these painted.
