Completed drilling rear spar attachment bolt holes after rechecking angle of incidence. Installed rear spar attach bolts, torqued and installed cotter pins. Attached both flaps and bolted them on with cotter pins. Installed flap push rods and bolted in place. Tested range of motion using flap motor and tested flap position indication on EFIS. OK. Installed both ailerons. Checked ailerons wing level positions and jam nutted all torgue tubes.
